I looked at that one too. The lobe lift is basically the same as the other ones just less duration obviously. Will talk to Hughes on Monday and see what they say.
Can you tell if Comp is measuring their lobe lift @ .020" because it's lower than the Hughes. .283 vs .315/.320.
