if he has contact with 0 lash and no headgasket, he has problems! the question is how much interference is there? also are you sure the cam is in at 110? if you factor .040 for gasket,.020 lash that's still only .060 minus the exact amount of interference. advancing to 106 might help, but not fix the prob.
