The numbers on the trans are PK 52118732 1585 2226 which means it is a A518, w/5.2L Eng. w/Electronic T/Converter Lock-Up, After 10-1-1992
However it doesn't have the 8 pins connector but the 3 pins connector.
The previous owner told me the trans came out of a 95's B250. However I don't know if this has anything to do with the fact that is was a European van. As being a overseas moparts member.
