Keep in mind for any car you install this in:
The orientation this was mounted in the 'Vic is part of the caster 'equation', so that must be taken into account when mounting it into the new car. If you simply mount it 'flat' into the new car there might not be suitable range of caster adjustment.
The 'Vic framerail angle with respect to the horizon should be compared to the angle on the receiver car.
Does this mean we'll see an influx of 4.6 engines installed in Mopars???
