The upper control arm cam bolts need to be torqued to 65 ft-lb. You can't use a box wrench and call it good, you need to get on there with a torque wrench and make sure you get to 65 ft-lb.
If not, exactly what you described will happen.
Bob
AAR 4-speed 3.91, Tor-Red;
70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy;
68 Formula S conv 383 4-speed 3.23, Electric Blue;
69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue;
78 Lil' Red Truck, Red;
70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
