Congrats on the new best as you have it running real good. I always wonder just how much the boost makes it pick up ? I mean if you took the turbo off what do you think it would run ? I am just curious of about how much the turbo helps as it seems many of the fast turbo cars I see have engines that are not all that heavily built and are closer to stock then I thought. It does surprise me how well some of them hold up under boost. But you sure have it running good. Ron
