I've been hitting mine with 18.8 psi of boost and spinning it to 7,000 for quite some time on the stock block with factory caps and bolts and no fill. I'm betting you still have LOTS of room left to work with. I think the "myth" about how much these blocks can take is based on failed parts with bad tunes.
