Not surprising that a looser converter is quicker. People get caught up in converter efficiency thinking that will make the car quicker. That is seldom the case. Lower slip numbers generally equal slower ET's, but they put less heat in the transmission and are generally more consistent. Generally speaking looser less efficient converters are quicker in the car, put more heat in the transmission and are less consistent.
