Interested in your combo would you share more info?
30 over 318 magnum Lightened 340 crank, scat rods, diamond Pistons Magnum RT heads, 2.02 valves, massaged. Dual plane, air gap knock off 950 proform 231-238@50 hydraulic cam, 595 gross intake lift 10.44 compression Cheapy 99 dollar 1 5/8 headers into dyno max bullets 8 inch convertor 904 4.10 gear, 28 inch tire, 3415 with me in it, flat hood. 71 New Yorker rear shocks, CE 3 way fronts, shift at 6200, trap at 6000
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
