What was the reason it wouldnt rev? I assume its fixed?
Timing was off, guys at a shop next door used a fancy setup( digital deal) and set it wrong. I went and bought my own light. Plus this little motor doesn't have a lot of grunt from a roll in high gear. Had too high of fuel pressure( 8), changed it to 6.5, new plugs, and the 750 shiny new carb is a dog
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
