1969 383 Superbee with MOPAR electronic ignition (distributor &
orange module). Car always started & run perfect all these years.
Restored 6 years ago. Battery perfect and turns over great. When
it first acted up a friend jiggled the wires on the resistor. It
then started up. Put on a new resistor. It ran and started fine for a couple days. Then.....same thing again...no start. Checked
the connections on the resistor. A little loose but tight enough
it should have started. Maybe it's the orange ignition module.
Replaced it. Ran and started fine for a couple days and then again it wouldn't start. When I let off the key from the start
position it "pops" like it wants to start. I tightened up all the
connections going to the resistor but still have the intermittent
won't start problem. Could it be the ignition switch?
