I will say, even if the car was race only, with limited street use such as your cars, I would still run a small block just so when I do beat up on ya, It would feel that much better!!!!!
If it'll run EIGHT SECONDS with a small block, I'm sure SKR8PN would ! But how likely is that?
Small blocks are easier to use in a milder-performance build. They're cheaper, plentiful, and leave more room under the hood. If that's what you are after, there is nothing wrong with them...but I doubt that the SS/A or Pro Stock guys will be trying to compete using one.
All things equal, there is really no argument that more cubic inches = more HP and torque.
However, there are certain applications where small-displacement engines are more desirable:
ROTFLMAO!!! Brion I owe you a for that one!!
Karma has no menu. You get served what you deserve.
