When you put the floats in, wedge to the rear, turn the bowl upside down, measure the distance between the top of the float and inside top of the bowl. Set the float level to .425. Make sure fuel pressure isn't over 6 psi.
Mark Whitener [url=www.racingfuelsystems.com[/url]
