Hello Tig. You shouldn't have floats with notches, you need floats that are shaped like a wedge on one end, these will be orientated left and right with the wedge facing reward. I have never seen tunnel ram floats with jet extension notches and wedge features on the same float. Jet extensions are not necessary (or desired) with sideways mounted carburetors. I would go back and visit that before trying anything else. The floats have wedges and are fitted so the wedge is to the rear, they also have notches for jet extensions. They are not the same as the ones linked to at the start of the thread. http://www.quickfueltechnology.com/fuel-bowl-parts/nitrophyl-float-wedge-primary.htmlPretty sure my hood is causing a problem as we can only just get a 2 1/2 inch tall filter in there. We have filter tops too which are real close to the hood.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
