The new Edelbrock/Carter AFBs in either 600 or 750 CFM size seem to work well - size depends on the rest of the combo, of course. You might consider modifying an aftermarket baseplate to fit the larger air horns on the new carbs. I think there's also someone selling ring adapters for use with the OEM (smaller, as noted previously) air filter baseplate.
