So the question is...do I pursue quench as that would raise compression and I don't know if I have the know-how to even attempt that OR try a fatter head gasket (and lose power with lower SCR) OR go to a more cam to help drop the DCR?
In a 499, would dropping the hydraulic flat tappet for a roller setup with a more appropriate grind fix my problem and get significantly more power?
