Read what the previous said."Hooks good on a fairly well prepped track". I tried them when they first came out. Ya, everything was great until you got on a marginally prepped track,then was either hit or miss. And yes every Stock/Super Stock is on a radial,but when you go out are you on a national or divisional prepared track. A lot may have to do with how much power you are making also.
Pro Bracket radial was just released from Mickey Thompson last month. It's not like a regular radial slick, it's supposed to be the pro compound on a 29.5 tire.
