I used the shim gaskets on my 383. Heads had a cleanup cut but block still has the factory cut on it. No sealer, put on dry. No leaks, even with a 150 shot. My pistons are .014 on the hole and, yes, the thin gaskets raised my compression from 8.8 to 9.2. I'm glad I bought a new set for the new bullet going together.
