Quote: I would go with Fel-Pro head gaskets and skip the steel shims. You'll get a better seal, and you'll only see a 3 or 4% difference in compression ratio. Mancini Racing sells the steel shim gaskets if you are so inclined. Or check Summit or Jegs.
If you do use steel gaskets get the copper spray sealer and do both side of the gasket.
