Originally Posted By MikeyT
good idea, I was thinking the same thing too John double R! Also, I was wondering if my 3600 stall ptc converter might need a separate cooler to relieve the temp on the radiator.
Mikey
Adding one is not a bad idea, the added heat load of the trans is not helping, BUT it's not adding much of a heat load at idle.
Check the flow thru the rad first as suggest with a towel.
