As I recall, torque specs on my e body steering box mounting bolts is like 85 to 100 pounds and is a bit hard to achieve using almost required flex sockets. Hopefully a torque wrench was used, if so should have held,,,,unless female threads or male bolts are in poor condition. Perhaps you can check this out before closing out.
