More CID = more low end torque. Means less rpm, less gear, less valve train strain, less cam required, etc... All good things. 4"+ is a no brainer on a tall deck.
That being said... If you already have the 3.79“ your not going to build a worthless combo by using it. It all comes down to budget at that point.
