Originally Posted By rowin4
So do you guy's know someone at the airport? the air ports I've been to have the area all fenced in and you have to go through the building , then through a locked door. If you don't have a plane, you don't get passed that door.
That's what it's like over here now. I used to use it in a 282ci hemi 6 with 12.9 comp, solid lifter engine. Ran Best with 50/50 mix 98pump (your 93) and Av Gas. The motor felt slightly less responsive with straight Av Gas probably because it's a slower burning fuel.
Peter. Australian Charger, alloy block injected 410in, w9 na 9.03@148 leafs 3000lb
1967 barracuda 605 hemi Stage5 millennium 8.2@170
