Hookers. I'm curious about the teflon in the line comment. I need to remember what brand it was and look it up. remember the fittings being na red package.
Most of the aftermarket companys that sell the AN fittings and lines sell the fittings for the teflon lines and the lines, the fittings are different so don't plan on using any fittings you have for neopreme on the tefleon line ends You will need the #12 O ring male fittings for the pump, straight, 45 degree or 90 degree. I'm not sure if any of the 45 or 90 degrees come in a regular fitting that do not need the locknut to make the O ring seal, those fittings are not teflon specific Either way order what you need. You can order the teflon end fittings in straight, 45 or 90 degree ends also Good luck, post a picture when your done ![](/ubbthreads/images/graemlins/thumbs.gif)
