I noticed that the dual line setups use the rear port off the pump cover.
Can I use that for the single line setup? I think it will clear by a mile if I can come straight off that port.
I'm not sure why I have it ran to the side port as I put that on over a year ago and had to stop the project. I have a feeling that there is a reason why that one was used.
