Quote:Quote:Quote:Quote:Anything you can convince the county to issue a plate for. Sounds great... until you're 75 miles away from home and have no idea where to get 110 octane for you 12:1 race motor. Pump 93 will work fine in it as long as you don't drive it hard. If you can put pump swill in it..... Then its good.
