Wide gear ratio or a gear ratio comprimize is all that's left for you.
Go look at the specs of the Passon OD conversion gearset then come back and comment on compromises and wide gear ratios.
In a nutshell:
Passon's 5 speed and a standard 833's 1-4 gears are almost identical ratio's, making the 1-2 shift RPM drop the same - from 6000 to about 4400.
Both the TKO's 3.27-1.98 1-2 ratios and the Passon Hemi 4 speed O/D's 2.66-1.59 ratios drop the RPM's on the shift from 6000 all the way down to about 3600. The 2-3 on the TKO drops to 4000, and the 3-4 to about 4400 - the Passon 2-3 to 3800.
So, by the specs - both the TKO and the Passon 4 speed O/D are wide ratio transmissions and a compromise. If you need closer ratios - stick with and 833, or wait on your Passon 5 speed.
Personally, I think both the TKO and the Passon Hemi O/D 4 speed's 6000-3600 RPM drop is an excessive drop for most small blocks, and marginal at best for a big block. The TKO's advantage is a lower 1st gear, and less RPM drop on the 2-3 and 3-4.
Free advice and worth every penny... Factory trained Slinky rewinder.........
