Re: American Power Train 5 Speed Install
[Re: 71birdJ68]
#1778076
03/14/15 01:16 PM
03/14/15 01:16 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Does it bolt right in, NO., can you use any of the factory stuff, NO. Can you undo it later if you want, NO. With the Passon, you get both.
In my case, my car is an auto on the column. So even to go with a 4 speed od, technically be hacking the car according to posts here. Yes you can use the original clutch linkage, pedals etc...
To each their own, but even in my 5 speed truck, I still want to shift to a 6th gear. Now to go to a t56, that takes cutting up a car, crossmember and so on... that's one I wouldn't do to my car.
