Your axles will work for in a dana 60 as well as a ford nine inch. You just need to tell the manufacturer to put Mopar ends on or weld them on your self. Then your existing brakes will also work. Same for both rear ends.
the next poster says I am wrong on the dana 60 that the axles are different lengths. I do know the nine inch will work.
Brett Miller W9 cnc'd heads STR Chassis fabraction
