I run a generic Summit radiator. The dual fan set-up is out of a new Challenger. It fits easily and the shroud is part of it. These fans MOVE some air. Not a great pic but you can see the upper mounting bracket. The lower bracket is similar.
Doug
I am guessing the motor would make around 550-600hp.
Doug like that setup. Can you tell me more about the radiator or have a part number? On the double fan setup...that's lind of what I am looking for is a part I can grab from a parts store do you have the fans on Thermoswitches? Do they come on at the same time or incrementally as temperature rises?
If you go with the double fan set up like Doug has
you can have each fan come on separately if you run
2 thermo switches with each set at a different temp..
the thermo switch I bought was about $18 if I recall..
just weld on 2 bosses to the radiator tank with 1/8"
pipe thread.. the switches come with a 1/4" temp
probe that you install with a compression fitting
