I feel pretty good about it as everything fit together perfectly and moved the rocker shaft back and up which solved all three of my problems (installed height, retainer clearance and geometry).
I did enlarge the holes in the shaft in order to offset it on the stands/spacers. The amount of material removed was not excessive but as you know time will tell how everything holds up. Your thoughts?
