I was kicking the idea around about using a Daytona chassis for a ladder bar small tire car.
Is this a possibility? Where would a guy start? I believe Mopar used to sell a kit to convert these to RWD...... What did this kit consist of?
By the popularity of the Fox body in small tire racing I figured the Daytona is similar in size and weight..... It's just the fwd that messes things up.
That kit consisted of 3 tubes basically, front one was part of a K-member, trans mount tube and I think the third was the rear upper shock mount... that kit is no longer available from MP.. but I heard there was someone making his version... but in that class I dont think you want to go that way
Do you have to fab a trans tunnel for the Daytona?
1971 duster twister 440, 3380#,509 M/P hyd,906's,full Exhaust,11.06@117.46 1/4,6.95@ 97.03 1/8,1.497 60ft.....
