I would use the longer one. Should work better.
How and what is the difference, if the spring length and spring preloadbar is shorter vs. longer?
When going to a longer front spring segment, in almost all cases, you move the Instant Center closer to the 100% anti-squat line, which, in almost all cases, is a good thing...
I should have been more clear as I meant use longer spring caltrac bar not mount. Sorry for the confusion.
Brett Miller W9 cnc'd heads STR Chassis fabraction
