I am going a little different route on my project.
I am going to use a front segment from this kit (if they will sell it to me)...I don't want to have to take the springs out of the truck
http://www.srdparts.com/index.php?page=s...t&Itemid=1. and I have to modify the existing truck spring plates to accept some mounts I took off a ladder bar kit, because their spring plates don't have the shock mounts I want and I am going to swap the spring plates from left to right so that I can mount the shocks in front of the axle rather than stock behind it. Then I will use the roller kit that I got to anchor the rear of the leafs. It will all make sense when I put it together
![](/ubbthreads/images/graemlins/confused.gif)
