Quote: John... why dont you go with Strange struts... WAY CHEAPER and it includes everything you need (brakes springs, lower A-arms.. everything except the rack... its not hard to install at all... but I dont know if you play in a class where you cant run the struts $1900 gets it all
what he saves in upfront money he will spend more on the install. that 1900 you throw out there does not include the rack, steering shaft and u joints or a jig needed to install the struts properly. A alterkation can be bought and bolted in with basic skills. CHEAPER hardly ever is better.
