E68 engine pulled from an old highway patrol car with a 3/4 race cam......
...or it could be a R3 block 4" stroke 439 W8 combo. 264-272 @ .050 108lsa .750 lift at retainer, 13.5-1....750 cfm double pumper. should still creep into the 9's in Vegas. Needs a little more gear....4.30 in it right now.
Nice! What converter and how much does it weigh?
Man that is too cool running 9's with a worked 750 dp!
the driveline was basically untouched from our W5 era. We have 2 converters from Ultimate and currently the 8" is in there. We also have a 9" that may actually be better suited to the torque of this thing. Got to get alot ironed out before we start playing with converters. I actually saw quite a bit more trans temp on these passes, but so far attributing that to the "automatic" shift at the hit. Dropping from 6200 rpm to 3500 will create some heat Car weighs just a bit under 3K with driver.
