My SCS Cheetah does the same thing in the demon. I have a sign on the front bar that says "Hand off the shifter" so I do not get to 2nd right on the launch.
Nice passes.
I've got that 1st gear detent dang tight now. If you ever feel in the mood for improvement, drop your valve body, shim the spring behind the detent ball, and file that first gear slot a little deeper
