Re: rocker shaft shims, what are they good for?
#173702
12/24/08 10:06 AM
12/24/08 10:06 AM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
this is what can happen. i'll build a new stand and fix it, but i know my customer wishes he'd never heard of those things.
Dan,we see that alot with both iron and aluminum heads.Mostly when some one puts a washer under the shaft and trys to fit it by cranking down the bolt or stud nut.Generally we just machine off the stand and make a block with a through hole for the shaft and vertical hole for the hold down stud or bolt.That way we can offset the shaft hole up or down vertically or laterally to correct the geometry.On high lift,high pressure applications we add a locating pin to indicate the block to the head to keep the blocks in place since the holes for the hold downs need to be oversize for relocation and oiling.The block with 100% contact around the shaft and the large seat area(block to head)makes for a stronger attachment for the shaft and allows for unlimited correction capabilities.
Entire Thread
12/24/08 03:47 AM
dirtybee
12/24/08 04:07 AM
12/24/08 04:36 AM
MR_P_BODY
12/24/08 04:48 AM
tjmarcus1
12/24/08 03:01 PM
tjmarcus1
12/24/08 07:06 PM
MR_P_BODY
12/24/08 07:30 PM
Bob_Coomer
12/24/08 07:36 PM
cl440
12/25/08 07:54 PM
sixpackgut
12/24/08 04:38 AM
12/24/08 04:53 AM
sixpackgut
12/24/08 05:01 AM
prochargedhemi
12/24/08 06:01 AM
dirtybee
12/24/08 08:00 AM
493_DART
12/24/08 09:37 AM
CokeBottleKid
12/24/08 12:24 PM
boscosis
12/24/08 12:28 PM
CompWedgeEngines
12/24/08 02:38 PM
12/24/08 03:00 PM
B G Racing
12/24/08 03:02 PM
SKR8PN
12/24/08 12:43 PM
12/24/08 01:52 PM
440Jim
12/24/08 01:38 PM
B G Racing
12/24/08 02:06 PM
RyanJ
12/24/08 02:10 PM
12/24/08 03:46 PM
B G Racing
12/24/08 03:54 PM
Streetwize
12/24/08 04:08 PM
12/24/08 05:43 PM
Bob_Coomer
12/24/08 05:48 PM
BradH
12/24/08 06:49 PM
BDS871Cuda
12/24/08 07:08 PM
WadeMetzinger
12/24/08 08:20 PM
WadeMetzinger
12/24/08 08:22 PM
WadeMetzinger
12/24/08 08:25 PM
Streetwize
12/24/08 09:08 PM
Moparnut426
12/24/08 11:33 PM
BigRay
12/26/08 01:31 AM
