Big Ouch!
i'll correct the geometry for him without the use of conventional shims under the shafts and make a new stand to replace the damaged one.
i'm not sure if anyone cares, but maybe i'll post pictures of the completed repairs.
1) Are you going to mill it off and use the bolt/stud to hold the fabricated stand in place?
2) What method are you going to use to correct the geometry the guy was trying to adjust with the shim under the shaft?
