I usually pop the t bar clip, undo the LCA strut and the LCA pin nut, THEN I back off the torsion bar adjuster and use a pickle fork between the K frame and LCA and pry the LCA backwards. Never had one stuck yet. No special clamps or tools needed.
I DO THE SAME BUT USE A PRY BAR
