Quote: I got a set of 360-1's they are the cnc 245's but the raised port vesion. Ryan did them and said they more around 255cc and I remember a set he did on here in the 365 @ .700" lift range. I also have a magnum block and T&D 1.7 shaft rockers. I have the MRL Performance offset lifters and spin mine to 8K with no issues.
So you can run offset lifters on a 59 degree block? I inquired about this a while back and several chimed in and said the link bars would snap almost immediately.
