The big thing to keep in mind on pinion angle and driveshaft angle is at the rear U joint the pinion shft and driveshaft should never be perfectly aligned sitting still, there should be visible V, even if it is only 2 to 3 degrees difference Never a upside down V All U joints need a difference in angle for them to work correctly, the needles need to rotate due to the diffeence in rotating angles or planes
On a big tire/chassis car many times the centerline of the crank is lower than the centerline of the pinion. This makes the driveshaft run "uphill" towards the rear axle, leaving the rear u-joint angle in an "upside down V".
Free advice and worth every penny... Factory trained Slinky rewinder.........
