Using the stock head gasket as a template, if you take the Sunnen AN-980 chamfering cone and put a radius on the cylinder for the intake valve you will have plenty of radial clearance. And I can't believe a cam of that lift is going to hit anything.
2011 Drag Pak Challenger
