I agree, trans go changed the throttle pressure spring and instructions several years ago, so go by the instructions that came in the kit.
When I rebuilt my transmission, I tapped the front clutch apply hole for an aluminum plug that I drilled slightly larger than the plug that came in the kit. That makes it easy to remove, and change the restriction size, but seemed like overkill since I never changed it.
