I don't blame anyone for wanting a T56 Magnum with the sweet ratios. Be aware though that the Viper T56 has the 1-4 of a close ratio Magnum and the 5th and 6th of the wide. There have been 1000+hp V10's running through them since the 90's, so don't get hung up on torque ratings unless your car weighs 4500lbs. Where im going with this is the Viper T56 is THE best fitting T56 in an A-body period, and if you keep your eye out can save some money over a Magnum.
