OK, have a 2011 Ram w/54K miles. It set a trouble code today, P0016 (Crankshaft position-camshaft positino correlation bank 1 sensor A, and P000B (Exhaust B camshaft position slow response bank 1). Sounds like the beginning of trouble with the variable valve timing feature. Anyone familiar with this? Thanks in advance.
"IF YOU'RE UNDER CONTROL, YOU AIN'T GOING FAST ENOUGH."
When is the last time you changed the oil? Did you put the proper weight oil in? Dirty oil or the improper weight will do that.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
