OK, have a 2011 Ram w/54K miles. It set a trouble code today, P0016 (Crankshaft position-camshaft positino correlation bank 1 sensor A, and P000B (Exhaust B camshaft position slow response bank 1). Sounds like the beginning of trouble with the variable valve timing feature. Anyone familiar with this? Thanks in advance.
"IF YOU'RE UNDER CONTROL, YOU AIN'T GOING FAST ENOUGH."
