It went 124mph at 10.84...
The Wallace Racing calculator says 124 mph at 3480 lbs is 531 flywheel horsepower. ET is 540 hp
Both ET AND MPH are way way down. Just a high side ignition miss wont bring back that much missing ET. ET is all made up in the eigth mile. Who specd the cam, and what are all the numbers on the head CFM, just not the "big" number?
RIP Monte Smith
Your work is a reflection of yourself, autograph it with quality.
WD for Diamond Pistons,Sidewinder cylinder heads, Wiseco, K1 rods and cranks,BAM lifters, Morel lifters, Molnar Technologies, Harland Sharp, Pro Gear, Cometic, King Engine Bearings and many others.
