Post a picture of your last ET slip from the track. HP is seen as MPH on the ET slip. If you were running 134 at the same ET, it would show you the problem was with getting the car off the line, etc... Just curious if you possibly have an RPM limiter on the car that's engaging at the top end, limiting your RPM. Just a thought. TD
It went 124mph at 10.84...
The Wallace Racing calculator says 124 mph at 3480 lbs is 531 flywheel horsepower. ET is 540 hp
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
