Quote: With the Indy-1 and SR head external oil kit if used you can tap the inside of the brass fittings for Holly jets and use .052 to .075 jet sizes to restrict the oil.HS and other rockers that use the needle rollers on the shafts tend to bleed more oil.
This seems the most simple way. If I start to mess with the small brass screws Ill probably just end up and
At idle wouldnt some 10-15 Psi of oil pressure be more than enough???
